I am new to home theater. I have a living room that is almost 19'x19' with some openings at the back of the room and 9' ceiling. I have just purchased a reconditioned Onkyo TXSR602 reciever and my speaker wires and cables. Now I need my speakers. Because the the way my living room is shaped I need small satelite speakers for the 4 rear surround speakers, I plan on a 7.1 system. The side surround speakers will have to be mounted close to the ceiling on mounts or hanging from the ceiling and tilted down toward the listing area. The rear speakers will probably be mounted in the same fashion. Because of the size restraint I have been looking at the Infinity TSS-750 set. I have found this set reconditioned for just under $400.00 which is my budget at this time. That doesn't include the 2 rear speakers but I will add those in a few months. My question, does anyone recommend any other speaker packages that I should check out in this price range? I have only been to Circuit City and that was the best sounding set for the price.
Thank You for you help!
