I Have Denon 2805..which budget amp do you recommend?
N
newaudiophile
I have a denon 2805 receiver and have the following setup...
1 room with 4 speakers + subwoofer
7 rooms each with a pair of speakers
Looking for a good budget priced powered amp...
Thanks!
N
newaudiophile
Thanks...
To be honest, we usually use only listen in 1 room at a time, so the reciever on its own with a selector box has been sufficient. We are having a party in 3 weeks and want to get all the speakers to work, including the outdoor ones so i thought we would probably need an amp or a another reciever.
We are probably going to use all the speakers at once only probably 2-3 times a year max. I would like the most budget way.....looking to spend $1000 or less.
Thanks again....if you guys have any more thoughts i would appreciate it!!!
