With the turntable's built-in pre amp, it's signal output voltage is no different from any standard analog audio source, such as analog audio from a CD or DVD player. You can connect that turntable to any integrated amp or receiver.
There are plenty of good amps/receivers available in the 50-100 watts per channel range. As long as you have adequate power to drive your speakers you will be fine, and those speakers you mentioned are not difficult to drive. The salesman at the store where you buy them may try and sell you a much higher powered and more expensive amp, but it isn't necessary.
Speakers are a more personal decision. I can tell you what I like, but you must listen and decide what you like. What price range are you considering?
