I have a question about subwoofer eq's
JBM1976
do they make them sound that much better? I see a svsound AS-EQ1 on ebay. Is that any good? Worth buying or not?
Sputter
Will it make a sub sound better? No it won't.
Will it help get the most out of your sub in your room? Yes it will.
A crappy sub will still be a crappy sub however.
I have experience with the svs EQ, people seem to like it though.
tattoo_Dan
tattoo_Dan
I have a really hard to make work room for bass,so I just bought an EQ(8033C) for my system,and so far I love it,my paradigm DSP-3200 has never worked better in my ht room,I have added a Emotiva sub 12 and it eq's both perfectly in this hard to make sound good room I have,with the 8033C.
for $375 with free shipping http://www.simplifiaudio.com/room_correction/dspeaker.html
http://verkkokauppa.planeetta.net/epages/Planeetta.sf/en_GB/?ObjectPath=/Shops/vlsi/Products/8033C/SubProducts/8033C-0001
JBM1976
Thanks but I was just reading some reviews people say the svs eq is better but for the price you cant go wrong with the 8033c .
I was also looking on www.svsound.com and they have some B grade subs and a sub eq that was ether a return or open box or something.
https://svsound.com/store/index.cfm?fuseaction=category.display&category_ID=12
I already have two svs SB12-NSD Piano Gloss Black and they are great subs. my house has hard wood floors, tall old plaster walls and everything echoes badly. I put down a rug in the center of the floor that helps. I need to get some kind of fabric or something and hang on the one wall to help with the echo.
tattoo_Dan
tattoo_Dan
my ht room is nice and big,19x17 feet,but my hurdle is that this is a 1966 mobile home,with super thin walls and basically just plywood floors under the carpet.
