You can't repair these modern units like the old ones. They are constructed using surface mount components with robots using hot air soldering. That is why there are no longer any service guys. Repair is by board replacement, but the boards run out fast, and usually only one run is done. This is the throw away age, and they have made repair pretty much a non option.
So are all modern ones pretty much junk once
[they fail ? I’m worried mine could break Any day . I’ve had it shut off A few times on its own but it hasn’t happened in months.
QUOTE="AcuDefTechGuy, post: 1679006, member: 26997"]
IMO if an AVR has to warm up to operate/function properly, it's probably failing.
This Onkyo was a $1K AVR brand new from 2009, which is 16 years old.
Would not surprise me if it's failing.
If you have good speakers, I wouldn't even hook up the speakers to this AVR because there is a risk it might even damage your speakers.
[/QUOTE]
seems like it lasted a long time I remember the people at bestbuy saying this brand is junk?
