I have a few final questions....
shockemags
I got everything in and hooked up for the time being and I love it all. It looks and sounds way better than I ever imagined. I do have two questions...
I cannot get the 661 to put the video of the 360 up. I have the component plugged into the DVD slot of the components but when I select it on the receiver there is no video. There is audio from the optical. (sounds great btw)
Is there a way on the Harmony remotes to remove some of the options on the LCD menu for each device to just the ones I want.
Thanks to everyone for your help now and getting to this point. I am extremely happy.
mazersteven
mazersteven
Are we ever going to get some pictures?
Davemcc
Davemcc
Some receivers require you to assign the component video input in the menu. I don't know if the 661 does, but it might be worth checking out.
My wife is the Harmony guru in our house. She tells me that she can do darned near anything on it, so I would assume you could delete functions from the on-line set-up and download. She also says the Harmony tech reps are nice and very helpful if she has to call about something specific. It might be worth a call to Harmony.
AVRat
AVRat
How are you connected to the TV? The 661 doesn't upconvert to HDMI. So if you're only using HDMI, then you'll also need to connect via component to the TV.
shockemags
I just have HDMI out from the receiver. Can I have the video from componet sent to the TV through the HDMI?
