I built Acoustical treatments for dummies (me)
G
Grantc79
So anyways, I'm not carpenter and building my own acoustical treatments and making them look anywhere near decent was more than a little intimidating for me but I tackled it anyways and figured I'd share my experiences with everyone else here who might be considering the same.
I'll keep this as "leymans terms" as possible.
All total, I spent about 200 dollars on the whole project (thought I got a fantastic deal on the 703). That yielded me a 12 count of 2 x 4 acoustical treatments.
Here's the materials:
Owens Corning 703 fiberglass insulation
I somehow picked up 12 of the 24 inch by 48 inch by 2 inch thick boards for 105 dollars locally, expect to pay about 50 to 80 dollars more than that though.
http://acoustimac.com/products.asp
Roughly 15 2 inch by 2 inch by 8 foot long wooden boards
Find this anywhere for roughly 1.50 per board
Any thin, soft, and porous fabric will work. The broadcloth fabric from Hancock Fabrics would probably work (I picked up something somewhat similar to this stuff).
http://www.hancockfabrics.com/product/iMainCat/3232/iSubCat/3321/iProductID/9101/9101.html
About 3 dollars per yard.
Any thin cotton batting from Hancock Fabrics will also work. I just found the thinnest and airyest batting that I could find at the store and had them cut up sheets of that for me. Just go in and ask for batting, they will know what you are talking about :) Have them cut into 50 inch tall and 50 inch wide squares so that you can fully wrap the insulation with it.
This stuff is very cheap.
Next is rubber footings to put on the back of the boards to give them some spacing from the walls. I used 1.5 inch screw-through rubber feet, but anything will work really.
If you go into Home Depot and look on the aisle with the "felt pads for the feet of furniture so they don't scratch up hardwood floors" they will send you directly to the right aisle and section you are looking for. The rubber feet are just mixed in with those.
These are about 2 dollars per pack of 2 or 4.
Finally, go to a hobby lobby, picture framing shop, or other type of store and have them attach "wire hangings" to the back of each of your frames. They are very cheap and easy to install if you wish to do it yourself. Its basically just two screws stringing a wire across the back of your frame just like a picture.
This stuff costed me nothing because we own a framing shop, but it cant cost much.
Screws. Some 3 inch wood screws to build your frame. Some 1.5 inch wood screws to attach your plywood triangles mentioned below.
Once again not expensive.
The last material is just cheap and thin plywood. You'll cut this into triangles and run it across the corners of your frame to make them strong and provide a backing for the fiberglass boards so they will stay in place.
Also very inexpensive.
Construction is simple:
Cutting the wood is cake. You will be building 4 foot tall boards for the sides of the frames so simply cut however many of your 2x2x8's in half you'll need. Next take the same 2x2x8's and cut three 27 inch long pieces out of them.
The 27 inch long pieces are the top and bottom of the frame, the 48 inchers are the sides (note the 27 inches is 3 inches wider than your board because it will overlap the side boards to screw them together). Basically you just "butt joint" all the boards together and make a big retangle out of them. Use the 3 inch wood screws to tack these together.
Next take your plywood and cut triangles out of it. Put a triangle at each corner of the frame and screw it in using the 2 inch wood screws to reinforce the corner and to provide a corner backing for the insulation.
That takes care of the framing.
Next take the Owens Corning 703 and wrap a piece of cotton batting all the way around it. Next slide the batting with the 703 inside of it into your frame, it should be very snug but manageable.
Next take your fabric of choice that you are using to dress up the front and sides and wrap it around the front, top, bottom, and sides and staple gun it to the wood. Be sure to stretch it well to pull out all the wrinkles and whatnot.
Once you are done with that cut off the excess fabric, attach the rubber footings to the bottom corners, and attach the "picture hanging wire" somewhere around the top 1/3rd of the frame.
That's pretty much it.
Now granted these wont be the most beautiful acoustical treatments you have ever seen, especially on the back. But who really looks behind them anyways? These might not have a very high W.A.F. but if you have a dedicated dark HT room, managable wife, or are a bachelor and love ugly **** like myself they'll do just fine.
The quality control on ours was somewhere between **** and horse **** (occasionally lack of fabric made us put a staple somewhere where we didn't want to or whatnot) but I must admit even ours looks pretty damn nice. But I'm not your wife thank god so who knows.
Maybe next I'll post the easiest way to build a forgiving wife. Then I'll be rich!
I will post pics soon, probably tomorrow.
Me and 2 friends cranked out about 12 of these things in under 3 hours. Thats way more than enough to cover my 17 wide by 22 deep room.
jake5717
Thanks for the info I’ve been looking around for some good easy DIY panels. My GF recently bought a large map (2’ X 5’) and she wants to put pins in all the places we’ve been. I’m thinking I can sneak some room treatment in by telling her it’s some sort of pin board for the map do you think if would work in this scenario? Would the poster negate the sound absorbing properties of the panel?
avaserfi
avaserfi
The poster would negate some of the sound absorbing properties of the panel. Here is an example of how temperamental it can be, when looking for cloth to cover the panels it is reasonably important to get a cloth you can easily breath through.
With the map there the panels will probably help with some frequencies but higher ones will most likely get reflected.
jake5717
So do you think it would just be a waste of money to build somthing like this?
avaserfi
avaserfi
That I am not too sure about. It might help some, but I can't tell you for definitively. Someone with more experience would need to answer that.
What are you trying to achieve with the treatment?
jake5717
I’m just trying to get some panels up on the plane ol walls in the room. I think the building material is the really old stuff, wood with concrete and plaster so there are a ton of echos.
ParadigmDawg
ParadigmDawg
That one panel looks just like a cat.
chas_w
Nice job....please post some pics when they are all mounted in the room.
ParadigmDawg
ParadigmDawg
I would hang 1 or 2 on the ceiling above the listening area. May be a calico or something that is not too hairy.
DrunkenWolf
Greg, while I usually find your advice to be sound, in this case I have to disagree. If he goes the route you've suggested he'll likely experience an increase 'scratch' effects all across the high end.
Davemcc
Davemcc
You may find vocal clarity is increased if you place one of the extra panels behind the center channel, maybe a nice Persian or Tabby.
To complete the room, you might want to place a Liger in each corner to absorb some of the bass.
highfihoney
highfihoney
Nice work on the DIY panels,i should point out though that fiberglass is not the best material to put in your living areas of your home,there is very little difference between raw asbestos fibers & raw fiberglass fibers,both are deadly & should not be used in living areas,ive seen both fibers under a microscope when i was trained about asbestos & they are identical.
The main danger from fiberglass is the same as asbestos which is airborne fibers,under a microscope a fiberglass fiber looks like a fish hook with barbed ends,these fibers enter the lungs & become embedded in the lungs causing all kinds of different cancers.
For anybody thinking about saving a few bucks by making their own accoustic treatments out of fiberglass i suggest you spend some time researching fiberglass,there is plenty of research is out there in computer land to back up what ive posted about the real dangers of fiberglass.
http://www.mythen-post.ch/datei_mp_4_02/schadenersatz_mp_4_02.htm
http://old.betterinsulation.com/Timeline.htm
http://www.sustainableenterprises.com/fin/News/uneasy.htm
Johnd
Just to set the record straight:
Fiberglass and asbestos are not identical. Asbestos has long been proven to be a carcinogen. There are absolutely no studies establishing any causal effect between fiberglass and cancer in humans.
That being said, take the rest of highfi's message to heart. It is never good to inhale any fibers. It is particularly during the handling of these materials that the greatest risk (airborne fibers which can be inhaled) that safety precautions ought to be taken. I see no problem with using fiberglass, provided it is safely handled and permanently encapsulated.
highfihoney
highfihoney
Bad info jond,yes both fibers do look identical under a microscope & attach to the lung in the same way,ive seen them both side by side.
You mention studies in humans,what a load,there is plenty of info on the effect of fiberglass in lab animals & the info is not good,fiberglass has been proven to cause cancer in lab animals & it has been labeled as a carcinogen.
You've posted that you see no reason why people should avoid a known cancer causing agent as long as its encapsulated,in order for fiberglass to remain harmless it needs to remain non friable,in order for it to remain non friable it needs to be mixed with a bonding agent like cement or other paste compounds,simply wraping fiberglass in cloth leaves the product friable & exposure is certian.
Any proof that fiberglass is a safe product?
http://www.lawyersandsettlements.com/case/fiberglass.html
