I am thinking about getting a pair of Klipsch sp-1 used.
macersl
Here they are on the web:
http://www.klipsch.com/product/product.aspx?cid=24&s=specs
Does anyone have any experance or input on these speakers? I am currently running a JBL 10" sub that is a little lacking in bass. Maybe these will help.? I use my HT for mainly movies.
I have been using a pair of Klipsch KG 2.5 bookshelfs http://www.klipsch.com/product/product.aspx?cid=145&s=specs
as my mains since 1995 and eventhough they still sound great I feel like I might be missing out. Don't know if these SP-1 are the way to go but I think I can get them pretty cheap.
Also I will be upgrading to a HK 335 receiver. I have heard that the combination of HK's warmth and Klipsch's horns is a great match.
passionplay
RE: Klipsch's
Nothing sounds like Klipsch. I have 5.2's and 3.2's since 1992 and don't want to let go. Klipsch has a really good forum off their website- you might want to check it out.
krzywica
krzywica
Klipsch has a very unique sound make sure you audition some before you buy. Have you ever owned horn speakers?
droeses58
droeses58
I've gotta agree with hookedonsound, if your using the ht mainly for movies, those speakers may help a little but you should really consider a better sub first.
