I had a ground loop in my system coming from the cable. Ended up having to use a ground loop isolator on the cable coming into the house.
Is your TV connected to your receiver with RCA cables? (either for audio or video?)
My ground loop hum came into the cable box, and passed through the the receiver via the component (RGB) cables sending video to my receiver. It didn't start until I added a power amp to the system that used a 3 prong plug.
If all units are grounded on the same power bar, then there should be no ground loop there, it'll be on your incoming cable. Try leaving your entire system hooked up, but disconnect the incoming cable from your tv or cable box. If the hum goes away, you need a ground loop isolator.
Mine was about $25 from a place in toronto (tin-lee electronics)...
Good luck!
