will check
Thanks guys, will try out the things you mentioned and post tomorrow. I do have some type of cheapo coaxial DC blocker I bought from Fry's electronics, was about 3 bucks. It connected from wall coaxial between cable box, looks similar to the coaxial isolation transformer (basically a tube with female and male coaxial connectors), but I have a feeling it isn't the right piece as I saw the Jensen one was about 50 bucks.
Question, I understand the ground loop isolator from TV audio output to the stereo system input aux connector, but if I put one on (Incidentally, I bought one from radio shack but did not apply it since the hum was also coming from the internal TV speakers) and this stops the hum from the stereo, what about the hum from the internal TV speakers? The hum comes from both the TV speakers and the stereo speakers which leads me to believe it may be something else. Should I go ahead and see if I insert the new ground loop isolator audio line from TV to stereo stops the stereo speakers humming anyway?
Another note, by grounding the stereo to the outlet, would that effect the hum from the internal TV speakers also? I think the stereo power plug us only a two-pronger with no third ground prong.
