HTPC Video and Sound Stuttering
Bryce_H
Bryce_H
Hello everyone.
So a while back I posted about wanting to get bitstream over HDMI and my current system didn't support it. So I bought a new graphic card and got video and sound through the HDMI cable...for about 2 days.
Now I can't get smooth video or sound from my server, through my HTPC and it is driving me up the wall.
First my system(s)
HTPC:
Windows 7 - all updated
Geforce Drivers (latest)
Windows Media Center
EVGA 132-CK-NF79 motherboard
2.67 Ghz Intel Core2 Quad processer
Samsung SSD 840 Evo harddrive
2 sticks of OCZ3N1800SR4GK RAM
DVD drive SH-S203B DVD drive
EVGA GeForce GT 730 (2GB GDDR5) graphics card
Hauppauge WinTV-HVR-2250 TV Tuner card
Coolermaster RS-850-EMBA Powersupply
Server
Windows Home Server 2011 Service Pack 1
Intel Core i5-2500K
ASUS P8Z68-V LX
C: Drive Samsung 2TB
RocketRAID 2720 SAS Controller
Storage: Raid5 of 5X2TB drives
Network
Modem: Motorola Surfboard SB6121
Router: Netgear WNDR4500
Switch: Netgear JGS524 V2
TP-Link TL-SG1024
All my computers and my printer are on assigned IP addresses
Receiver
Onkyo HT-RC260
Everything hardwired through CAT5e
I record on my HTPC through the TV tuner card and WMC and then after bit (don’t know the exact amount of time) the recording is shifted over to my server (I have move recording over to my home server).
Disk space on the server is about ½ full for the folder “Recorded TV”
So I was previously running the setup listed above EXCEPT the graphics cards in the HTPC were 2 9800GTXs in SLI. I had video through a DVI-D to HDMI cable and sound through an optical cable. But depending on the program (WMC, VLC, streaming over the network) I sometimes would not get 5.1 surround sound…I would only get stereo and my receiver would decode it as Dolby Pro Logic II.
In addition with this setup there would be times we would start a show and the sound would be completely hosed – almost like pink noise. Sometimes “skipping” ahead or back in the recording would fix it, but not usually. Instead we would watch something else and come back to that recording another night and it would work fine.
So…I upgrade to the EVGA GeForce GT 730 (2GB GDDR5) graphics card thinking I could run video and audio through HDMI, get either PCM or Bitstream and be happy as a clam.
I install the card…everything works for about a day and then…the video and sound begin to stutter on every recorded show in WMC. The show is stored on the server in the basement…I am playing the file through WMC in the living room. Every recording does this.
I also sometimes get the Video Error stating: "Files needed to display video are not installed or are not working correctly. Restart Windows Media Center or restart the computer."
So here is the list of things I have tried:
1) Removed and reinstalled the graphics driver
2) Removed and reinstalled the NIC driver
3) Rebooted/cycled the:
a) HTPC
b) Server
c) Modem
d) Router
e) Switches
4) Tried 2 different switches (swapped out the new one (TP-Link) for an old one(Netgear))
5) Reran WMC setup
6) Set the WMC sound to 2.0, 5.1, etc.
7) Set Windows sound to 2.0, 5.1, etc
8) Tried every combination between #5 and #6
9) Turned on and off exclusive mode in Windows sound
10) Tried different HDMI cables
11) Tried different HDMI ports on the receiver
12) Tried different Ethernet port on the wall
13) Checked the health of my RAID array on the server - perfect
14) Played a recording from the server through VLC (although it played with a touch less stutter). As a side note: I just played a file through my office desktop from the server on VLC and it played fine.
So at this point I am at a bit of loss. I have scoured the web and forums for other ideas and come up with nothing different than what I have already tried.
Since I had the stuttering before the new card (but not all the time), I am hesitant to immediately blame the new card.
Thank you for any help.
BoredSysAdmin
BoredSysAdmin
try mpc-hc with evr renderer. I had some issues with mkv/dts shuddering on my own pc.
Bryce_H
Bryce_H
I have actually started to wonder if I go the XBMC (Kodi) route with WMC as my backend PVR...
Bryce_H
Bryce_H
so if I pause the show, wait a bit, and then start it back up...I get perfect playback for short period of time (about the same as the pause length)...is there a buffer/queue somewhere that can be changed?
Bryce_H
Bryce_H
So I recorded a show and left it on the local hard drive and it played fine; but as soon as I sent it to the server...it stuttered. So I am coming down to either the network or the server as the issue. I have already tried 2 different gigabyte switches.
Any ideas how to start determining what is the issue?
Bryce_H
Bryce_H
Ok, hesitant to call victory quite yet, but I went in the server Network Adapter settings and changed Speed and Duplex from Auto Negotiation to 1.0 Gbps Full Duplex. Things seem to be working now...so we shall see.
BoredSysAdmin
BoredSysAdmin
yes, now I remember - something to do with Auto Neg was messing up network stability.
sorry I forgot about it earlier. I did improved things much on my side as well
Bryce_H
Bryce_H
Figure I should set all the adapters through the house just to make sure...
Bryce_H
Bryce_H
So my victory was an illusion...the stuttering is back. I am at the end of my trouble shooting skills. I did test the same setup on my second HTPC in my theater in the basement and everything worked fine. I also set up WMC on my desktop PC in the office and everything worked fine. So I believe I have ruled out the network since it works fine in two other locations.
At this point I am considering the nuclear option and doing a fresh install on the machine in question. I figure this will get me a fresh baseline to start with.
If I do that how do I retain my recording schedule?
Other ideas are also appreciated. Thanks.
