Hi All,
I'm looking for some input on a couple system configuration options. The following things I've pretty much decided on:
-7.1 System in a 17X11 room (walls on 3 sides, 4th wall will make 11 -> 33 ft): These will 3xEnergy RC LCR, 4xEnergy RC10
-3.1 System in a 17x9 room (walls on 3 sides, 4th wall will make the 9 ft -> 33 ft): These will be 3xDefTech StudioMonitor 450.
I have for power:
-Denon 2312CI (105W/ch)
-Yamaha RX-V667 (90W/ch)
-Emotiva UPA-2 (125W/ch)
-Emotiva mini-X A-100 (50 W/ch)
Here's where I'm looking for some input:
Should I use the 2312 in the 7.1 System with the 667 in the 3.1 System and keep the spare amps for other uses. Or, would it make an appreciable difference to use the 667 + UPA-2 (fronts) + mini-X (rears)? Both systems are going to be 80% HT usage and 20% Music. If the Denon had pre-outs, my solution would be straight-forward: Denon + UPA-2 for the 7.1. But, unfortunately, it doesn't and hence the post.
My guess is that there isn't going to be much of a difference either way and I should save the Emo amps for other applications around the house. But, I'd appreciate input from the community.
Sorry for the long post and thanks for your input.
