Hello and Happy New Year!
I am in the Research stage of building a HT/studio and have been overwhelmed by the information on different sites, spreadsheet calculations, etc. I would like to create a room which I can use for movies, music and practice/recording studio.
Room: 20L X 13W X 9H (unfinished, concrete floor)
I have read on several sites that the best way to isolate sound would be to create a room within the room. I don’t want to loose space and it sounds expensive. Since I have a limited budget, I plan on doing most of the work.
Before I start:
1. Is it advisable to incorporate all of the above and if so how should I treat the room? (acoustics and isolation)
2. Will it do any good to float the floor and double sheet rock walls and ceiling?
3. Can anyone tell me how or where I can find how to interpret the attached spreadsheet?
4. Should I bite the bullet and hire a pro?
All suggestions and advice on products as well are appreciated.
Peace,
Eddie C
