HT speakers Klipsch or B & W
mastercraft
Just finishing a HT room in the basement, 14' x 19' x 6'5" tall. Plan on a Yamaha RX-V1600 receiver and a 5.1 system from klipsh RF-35, RC-35, RS-35 and a RW-12 sub or B & W DM603, LCR60, DM600 and a ASW600 sub. The room will have carpet and leather furniture. I'm into action / sci-fi and rock to contemporary jazz. What do you think.
corey
Both brands are good. As has been said so many times before, you've got to listen to them & let YOUR ears decide.
I brought a pair or Klipsch RB-35's home for a demo & liked them a lot.
Don't tie your sub purchase into your front & surround purchase.
Poshag
Ive got the same system as you, except with a yahama 557 and a axiom ep500 for my sub...I would say def look into axiom or SVS for a sub, the ep500 has made my system what I had dreamed it would be, and my room is a bit larger than yours. Only reason I didnt get the plus/2 from svs was because im in college and will be moving alot, so the 140 pounder didnt make sense, but I can't imagine needing more bass than the ep500 allows, i live in apartments/townhouse style homes and my neighbor three houses down said I knocked all the paintings off his wall my first day with the ep500
3db
3db
Wow dude.. Those are speakers at the opposite end
of the spectrum. With Klipsh being direct, bright and the B&Ws laid back and mellow,,almost dark sounding. You need to figure out which type of sound you appeals to you most and for how long
