I would take a look at the BIC brand of speakers though. They are very well made and pretty much the best you can get for the money.
I am debating on getting the DV5312, with a BIC center also and then getting two BIC DV52si's for the surround speakers. You can find the BIC center speaker on eBay for just under a $100, the DV5312's are floor standing speakers and are around $450/pair and the DV52's are bookshelfs that you can get at about $150/pair. This setup does not require a sub, but if you wanted you could even get a Dayton sub ($140) or Candence X-sub ($230). So that basically puts you at around $850 - $950 without shipping and probably if you went with the Dayton sub you could have it all with shipping included for under $1000 (if you went without a sub and used the floorstanders as your sub for now until to see if you really needed a sub then it could definately be had for under $1000 shipped).
Currently I am think about just getting the DV5312's and either a 53CLR or a 52si center. Either one of the centers can be bought on eBay for under a $100. The DV5312 have the ability to be upgraded at a later time (you can put an amp in them to power the woofers, they have 12" woofers in them already!!!) The amp for the tower is a 200 watt amp and you can get it for about $180 per amp, so $360 for the pair. If you wanted to do without the two surround speakers for a little while and just get the two DV5312 with the amps included in them (this would basically give you a very nice front two and essentially two 12" woofers) and then get a BIC center your price for the whole setup would still be around $1000 shipped (maybe a little more). I really like the option of putting an amp in the speakers at a later date because the DV5312's are a great set of speakers and if you put the amp in there they become powered towers with a lot of quality and depth to their sound. Have fun with your decision.
