HT Mag Tests the Pioneer VSX-72
E
EdS
I did not see this info in any of the other Pioneer A/V Receiver threads, I received my copy of Home Theater magazine and they testing the VSX-72 receiver. Very favorable review, here are the power measurements:
5 Channels continously, 8 ohms, 0.1% distortion: 143.7 W
2 Channels, 8 ohms, 0.1% distortion: 175.6 W
2 Channels, 4 ohms, 0.1% distortion: 212.1 W
2 Channels, 4 ohms, 1.0% distortion: 261.3 W
s/n ratio, A-wtd, @ 1W: 102.8 dB
This is a huge difference compared to the all channels power testing performed by S&V on the VSX-74. Unfortunately HT Mag doesn't really explain how they perform their power tests, but I do know from their testing of other receivers that their results are usually fairly close to the tests performed by other mags.
Khellandros66
Khellandros66
HT Mag may be our last hope for un-biased reviews on a mass print...everyone else seems to have gone the way of Consumer Reports with half assed reviews that are rushed.
~Bob
E
EdS
So, are there any plans for a review of the Pioneer VSX-72?
Please check S&V test what % they used for distortion to test at. I bet it wasn't 0.1%. or that 1.0% into 4 ohms. Of course you will get more power out at higher distortion levels.
Just be sure they are testing this or any component the same way, same distortion, same frequency bandwidth, etc.
