You can tune the VTF3-MK4 to whichever you like for both music & movies!
They recommend the lower 16hz tuning for music because music rarely gets that low. Electronica & a pipe organ will get down that low but not much else. Movies on the other hand have a lot of explosive dynamic peaks & a lot of the newer movies do get very low. So they recommend the higher 25hz tuning so that you can turn the sub up & not have to worry so much about pushing the sub past its limits!
Also, once you place a subwoofer into a room you get what's called boundary gain. This means your room naturally boosts the low bass. For instance I have my VTF-15H tuned to the Max Output mode 25hz. I actually measured my response & found that with it in the 15hz mode I got way too much low bass, way more than my midbass. So to even out the bass I have both ports open & EQ2. This gives me such great sounding, even & natural bass.
Plus this means I'm running it in the most efficient mode & it gives me piece of mind that I have plenty of headroom & the least amount of distortion.
Don't worry about how the different tuning modes are labeled (music or movie) once you get the sub home you can listen & choose the mode that sounds best to you. I still recommend the 25hz mode for most people. Again that's because your room will most likely boost the below 25hz frequencies naturally.
Make sure you do the bass crawl to locate the best spot to place the sub. If you place the sub in a bad location then the bass will cancel itself out at your listening position & it will sound horrible, like a fart. That goes for whichever sub you buy.
HSU makes a great sub, I can attest to that! SVS also makes a wonderful sub. For the money I still feel you get more performance for your money with HSU though. But others will argue that. At least you have narrowed your choice down to 2 really nice subs!!! I like how many tuning options the new MK4 lineup has. You can really fine time the bass with them!
