HSU to update MBM-12
Matt34
Matt34
Moderator
I saw this and thought it to be worthy to pass along.
Originally Posted by Pete - Hsu
Hi everyone,
I just wanted to give you some advance notice about an exciting new product announcement regarding MBM-12. To start, I would like to mention that we only have extremely low quantity of vinyl black MBM-12's in stock right now, and it will be several months before the MBM-12 is back in stock.
So you may be wondering, why will it take several months to re-stock MBM-12?
The answer to this question is that we have decided to re-design the MBM-12 and release a newer version later this year.
The new MBM-12 will have the following features:
1) Variable tuning capability! One can simply add or remove a supplied 4" foam port plug and flip a bass extension switch on the amp to switch between 'Sealed' or 'Ported' Mode
2) Wireless connectivity option will be available! This will make it much easier to position the MBM in the nearfield without running subwoofer cables across the room.
3) New finishes will be available! Standard finish will be Satin Black, and several luxury finishes will be available as well
So this unit will be perfect to use with the ULS-15, or any of our other true subwoofers. Price is still to be determined, and will have to go up a bit, but hopefully not too much. The size and shape and orientation of woofer/port will still be the same as the current MBM-12, but with all the changes mentioned above.
I am really excited about this unit, and hope you will be too in the months ahead!
speakerman39
speakerman39
Thanks Matt for the info. I think I have my Pluses sold, but still find this info quite interesting. Sounds like Dr. Hsu is at it again albeit refining one of his products. Kudos to Dr. Shu!!!!! ;);)
Cheers,
Phil
