I was set on purchasing the VTF-15H MK2, but it is on back order until the end of March. Since I'm impatient I'm thinking about buying the VTF-3 MK5 instead, since it is in stock. The specs between the 2 look fairly close. Is the 15H MK2 much better and worth the wait and extra $100 or should I just buy VTF-3 MK5?
Thanks
Previously the VTF 3 was only slightly better than the VTF 2, now it's only slightly inferior to the VTF15 (all based off of the measurements). This is a good move for HSU imho. However, if you're like me you'll always be asking yourself if you should have gotten the VTF 15!
That said, call HSU and see if you can audition the VTF 3, and if it doesn't live up to your expectations, you'd want the option of trading up to the VTF 15 plus the difference, when it becomes available.
That said, I'm not sure how attached you are to your HSU decision, but there are other ID brands which offer free exchange and return periods, no questions asked. You could always try on of those avenues.
