like i said earlier, i bi-wired the betas both ways, once with the 1015 hp & 5800 lp & vice versa. from past experiences with the 5800, i had a feeling that they would be louder when the 5800 was on the lp knowing the bass sucks more power...& i was correct. with the 1015 on hp & the 5800 lp, the overall SPL was on average 1-2 db's higher at the same volume level on the 1015 according to my SPL meter. however, with the 1015 on hp, there was more distortion from the highs when i turned it up. i then tried it with the 5800 on hp. although it was 1-2 db's quieter at the same volume level due to the 1015 not having as much power to push the bass out, it was also noticeably cleaner when i turned it up. i couldn't really tell a difference in sound quality at lower volumes, but obviously at higher SPL's (around 110 db's), it did sound better with the 5800 on hp due to the higher distortion of the 1015 when it was on hp. i'm thinking that when i get a good powered sub, it would be best to utilize the 5800 on hp & give up some db's...assuming the powered sub would more than make up the difference with solid bass, thus giving me higher SPL capability in the end since it doesn't distort as easily. after doing all of this, i know understand why it's recommended to use 2 of the same amps to bi-wire speakers!
i have to figure out if the additional cost of speaker wires & banana plugs is going to be worth it. btw, i didn't get a chance to test the 1015 or 5800 separately...i guess i just assumed it would be louder with the betas bi-wired so i didn't even bother...
