legendary70
legendary70
Hello. I have an Onkyo HTR590 running my garage setup. I have two infinity sm152's, sony center and surrounds and an Onkyo sub. Sounds great....but I would like a little extra bass without having to go out and buy another 100-300 sub. I have an 8 inch sub that came with a jbl surround system I bought. It is just sitting there in the garage. I know many people say not to connect a 10 inch sub with an 8 inch or a 12 inch with a 10 inch. BUT aside from that.....if I wanted to hook it up and hear how it sounds...how would i go about it.
The problem is the 8 inch does not have an rca connection....only the black and red wire connection. My onkyo sub is connected via the rca sub connection....(lfe I think its called). So how would i connect that 8 incher? Thx.
slipperybidness
slipperybidness
Sell both subs and take the $ to buy a "real sub". That is the best advice to accomplish your end goals.
markw
To use that other sub, you will need to buy an amplifier. Simply buy a bigger powered sub. It'll be cheaper in the long run.
legendary70
legendary70
thx. i will look into that sub. not a bad price.
