5 55katest55 Audioholic Dec 6, 2009 178 0 0 Sep 29, 2011 #1 I have to use the router my cable company gave me since its a router and a modem, so he told me if i wanna use my other, wireless n router, i will have to bridge it. How in the world would i go about doing this?! Thanks! Last edited: Sep 29, 2011
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,621 0 113 New Joisey Sep 29, 2011 #2 55katest55 said: I have to use the router my cable company gave me since its a router and a modem, so he told me if i wanna use my other, wireless n router, i will have to bridge it. How in the world would i go about doing this?! Thanks! Click to expand... Do you want to enable wireless with your router because cable company modem/router doesn't ? If so - you'd need to change your router to work as access point. The person who said anything about bridging is an idiot
5 55katest55 Audioholic Dec 6, 2009 178 0 0 Sep 29, 2011 #3 BoredSysAdmin...just the guy I was looking for. Couldn't think of a more perfect name for someone who could help me with this issue lol. Anyway, the guy probably was an idiot. All I want is for the modem/router to only act as a modem, and the separate router I have to act as a router. Something like this: http://support.netgear.com/app/answers/detail/a_id/965 Seems kinda complicated. I just want my wireless n speed and coverage range benefits! Last edited: Sep 29, 2011
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,621 0 113 New Joisey Sep 29, 2011 #4 55katest55 said: BoredSysAdmin...just the guy I was looking for. Couldn't think of a more perfect name for someone who could help me with this issue lol. Anyway, the guy probably was an idiot. All I want is for the modem/router to only act as a modem, and the separate router I have to act as a router. Something like this: http://support.netgear.com/app/answers/detail/a_id/965 Seems kinda complicated. I just want my wireless n speed and coverage range benefits! Click to expand... Notice how it's says on the link you provided - "To Configure Your Router as an Access Point" You need to find a manual for YOUR router and configure it as Access point No need to worry yourself with cable company router - it's already configured. Check IP address of your home computer - if it's 19.168.x.x and most likely its 192.168.0.100 or close If's completely different you'll need to configure your router as a router. Again - nothing to do with bridges Reactions: 55katest55
5 55katest55 Audioholic Dec 6, 2009 178 0 0 Sep 29, 2011 #5 Alright, sooooo...no such manual exists talking about how to set it up as an access point. If im understanding this correctly, i go into the crappy router/modem they gave me and uncheck "Enable Wireless Access Point" and "Allow Broadcast of Name (SSID)" right? Then just connect the other one?
5 55katest55 Audioholic Dec 6, 2009 178 0 0 Sep 29, 2011 #6 ah nevermind, a rep at another forum told me its not possible to use it and that i should request a stand alone modem and that if they give me problems he'll handle it. cool i guess.
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,621 0 113 New Joisey Sep 30, 2011 #7 As I said before - 1)Forget about you cable company equipment 2)Check your computer IP address and tell me it so I suggest further action accordingly
5 55katest55 Audioholic Dec 6, 2009 178 0 0 Sep 30, 2011 #8 Sorry, didn't catch that, thought you just meant for me to check it and not report back! It's 107.z. Btw, I've always wondered...is it safe to give out your ip address? Last edited by a moderator: Oct 1, 2011
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,621 0 113 New Joisey Sep 30, 2011 #9 55katest55 said: Sorry, didn't catch that, thought you just meant for me to check it and not report back! It's 107.10.xxx.xxx. Btw, I've always wondered...is it safe to give out your ip address? Click to expand... Not really, you should edit your post before it's too late Now I know you are from Tampa That means your cable company "router" doesn't actually do much of any routing - working as a modem only and just gives you external IP address. That also means you can not plug in multiple computers to in. The solution is a simple one - forget about Access point stuff i mentioned before. Plug in your router's WAN port to network port on your cable modem. connect your pc to LAN port of your router. Configure the wireless settings on it as desired. All your home computer should have IP addresses like ones I mentioned earlier - 192.168.0.xxx Last edited: Sep 30, 2011
1 10010011 Senior Audioholic Dec 13, 2004 654 0 0 NW Washington Oct 2, 2011 #10 55katest55 said: Alright, sooooo...no such manual exists talking about how to set it up as an access point. If im understanding this correctly, i go into the crappy router/modem they gave me and uncheck "Enable Wireless Access Point" and "Allow Broadcast of Name (SSID)" right? Then just connect the other one? Click to expand... go into your modem/router configuration and turn off it's wireless. plug your wireless N router in to the the modem/router using any of the LAN ports on your N router to any LAN port on the modem/router. go in to your N router and configure it as an access point and turn off it's routing and DHCP functions, forget about its WAN port.
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,621 0 113 New Joisey Oct 2, 2011 #11 Thanks Mike_C for the post edit
