I'm retrofitting an existing room to use as a HT room and still do not have a firm plan to soundproof the existing 110V receptacles. I'm GreenGluing 5/8" drywall and affixing it to the existing drywall. I can access the back of two of them, because the back of that wall is still open and so can box them in easily. But the others are a problem. 3 of them are shallow boxes in a furring stripped drywall roughly 3/4" from the concrete wall behind them !
I'm seriously considering eliminating the problem ones altogether - after all, I'm not going to need them in a home theater for any reason I can figure!
Unless a good sealing method pops up, I believe I'll be doing that !!
Eliminating receptacles just goes against my remodelling brain though, you know!
Any ideas?
