How to reset the DSP-Z9?
U
Unregistered
Guest
Hi all there!
I own a DSP-Z9 and some how there was going something wrong. Suddenly, evertime I start the DSP-Z9, Zone2 is active. Instead of deactivating it all the time manually, I would like to reset the DSP-Z9 to factory values.
Is ther anyone out there who can tell me how to do that? (BTW, i already asked the importer for Switzerland. He told me to press Balance and Tone-Control the same time, so I should get into a menu. But nothing happens if i press these two buttons.)
Thanks for any help!
Greetings from Switzerland
Ralph
M Lo
Unregistered said:
Hi all there!
Ralph
Hi Ralph,
Check the link below for the Yamaha RX-Z9. Quite sure it is the same procedure for the DSP-Z9.
http://www.yamaha.com/yec/customer/...reset_RX-Z9.pdf
Good luck!
Cheers,
M Lo.
