How to put itunes movie and music to non-apple portable player?
panpangege
I bought some video and audio from itunes and would like to put them to my portable player,but I am failure, whether they have protection or format require?---- how can I convert or transfer those files? Thanks advance!
CaliHwyPatrol
CaliHwyPatrol
The way I used to do it with music is burn a CD, then copy back onto your computer in MP3 format. I'm sure there is a much easier way though.
I don't remember what the file extension for Itunes videos is (mp4?), but usually a quick Google search for that extension to AVI converter will turn up a free converter.
Transmaniacon
Transmaniacon
I am not sure if Apple is removing the DRM from their videos too, but if the video is DRM protected, than you will have to resort to a payed program to remove that security. There are no free programs that will do it, only ones that will produce a lousy quality recording.
I have heard mixed reviews about burning and re-copying, it works for some people and not for others.
