Hello all,
I'm curious, where you are now with what you know and have experienced, how would you approach making a quiet room if you had the chance to do it over?
I think we are all used to having a room in the house/appeasement used as a theater or music listening area, while some have dedicated rooms made just for it. I realize it's not always in the cards to have a dedicated room truly to do what you wish with it for this. But, if you did, how would you approach it?
I soon will be building a new house and I will have the opportunity to have a dedicated room. It really is just going to be what would normally be the garage will instead be sealed and finished and be an extra room. So it will be fairly large, but not crazy big or anything. I'm not certain on the size just yet, just thinking ahead for this purpose. I'm curious how I should approach setting up the room based on what others would do who have a lot of experience with this stuff. I really like the idea of a quiet space, where it's less noisy than the rest of the house. The idea of doubling the dry wall with the green stuff between them and then treating the walls with acoustic dampening materials, bass traps, etc. But I'm curious, how much and how far to go with it? In my mind, I would adore a dead quiet room (not happening I realize, just wishing out loud) where it's eerie quiet. For filling the room, I have three towers and four 12" subs that will be doing the pressurizing of the room. I'm thinking I would like to find a way to do a sealed weather door into the room (and if I can avoid windows, I will simply not have a single window on any wall if I'm able).
So based on that.... if you had a large living room (garage converted to a big room just for your audio fun) with no windows and a sealed weather door, how would you approach treating the room initially and what acoustic dampening materials would you think to use ideally in such a large space? Isolation foam is fairly inexpensive and can literally cover every wall. Bass traps can fill the corners up fairly well. What about the ceiling though? And do you go with a hard floor and cover with throw carpets or do you go full on carpet?
What would you do?
Very best,
