How to know when its time to upgrade to a new AVR
tundraSQ
Current AVr is a Marantz SR7500 110watts by 7 with 7.1 analog outs.
Current source units:
Panasonic BD55 currently connected via analog to avr and hdmi to TV
toshiba HD-xa2 recently downgraded to dig coax to avr and HDMI to TV
both these units go thru an OPPO hdmi spliter.
Cable box is SA8300HD going into the AVR via dig coax and into the TV via hdmi
TV is samsung HLS56 dlp
I was perfectly content until i saw a link for a denon AVR on amazon for $549 I think it was the avr-898...so i started reading and now its like quicksand....the more you read the more you get confused and think i am better off staying with my current avr.
Most recent confusion comes into play when reading about HDMI repeater stuff. The Denons only claimed 2 hdmi 1.3a inputs, but i assume they are not repeating, and i don't even know if i need repeating.
And if i go with a switching AVR am i gaining "anything" over my current setup?
businessjeff
you would gain more space in your wallet for w/e you want, except probably money... :D
markw
Really.
What does the new one do that your current one doesn't? Or, what does it do significantly better?
Most "new" things give a few more fetures, which does not translate into better performance. And, as far as performance, I strongly doubt that any truly significant performance improvements have occurred within the last few years.
As for power, well, unless you are gonna double your power, don't even bothere and, even then, since you have preamp outputs, simply adding an outboard power amp will answer that problem.
But, if you simply want to spend money to spend money, have a ball. You don't need our blessings.
tundraSQ
I really just have an "itch" right now... absolutely no rational need to upgrade unless i would get noticeable audio improvements. I was just looking at the Denon 1909 deal at 6th ave...under $500 shipped. Then i could move my current AVR to my outside speaker system....so thats a noticeable plus right there...but no, in reality i don't see any huge improvements...
tundraSQ
Well in a moment of weakness, i ordered the Denon 1909 from 6th ave.
This allows me to return my Oppo Hdmi switch so in effect for $386 I am getting the 1909. Plus i will sell my SR7500 and get maybe $200 for that...so now we are down to $186:cool:
Thanks for all the help guys!!!
Analog signals are amplified when long runs are used, or buffered when sources are connected to a controller and distributed. Digital signals aren't amplitude dependent, so they go through a repeater which may/may not fix any errors present, using parity bits. Since digital is on/off pulses, if it's there, it can be repeated.
If you're using a universal type remote and have macros set up for turn-on, you'll need to wait almost 8 seconds after turn-on with last year's models before sending commands to the receiver. For instance, if you turn everything on, send input commands to the receiver at the very end of the macro. You may need to add delays, too.
To answer your original question, when it can't do what you need it to, doesn't sound good or is uneconomical to repair.
tundraSQ
update....i was just on the 6ave site checking my order....and it seems the 1909 is not going to ship for 10 days...but they now have the 2309 online for the 25% off. And it is in stock and shipping immediately
so for an extra $70 bucks it was a no brainer:D:D:D
if anyone cares....
