That, or if the product has a pre-out RCA connection, you can connect that to the subwoofer.
You don't want to use 'RECORD OUT' as those outputs will be fixed level vs. adjusted through volume. I can't tell on that unit what connections are on the back for audio out. I'm expecting what you described makes the most sense.
