Fm Vs. Cd's
GIDIEON! I have good news for you regarding economical but very effective tweaks you can do to make your cd, tapes, vinyl and fm sound better than your preferred fm only view.
Many of the threadsters here are not answering alternatives or solutions to your problem.
I am normally on the high end group at ecoustic which has much more technical gurus than i on internal electronics, but when it comes to tweaking, that is my expertise. I am former high end home theater and audio installer.
There are inexpensive tweaks you can do to enhance your system.
You can get a carver sonic holography or hologram, most are built in on carver preamps but the H-9 or H-9AV can often be sold at ebay. That was made in the early 80's thru the early 90's. The original holographic processors was by omnisonix called omnisonic imagers which was made in 1978 and even made car models back in 1982.
The other inexpensive but newer sound processor is called an ACOUSTIC RESEARCH TDS-202 which was made in 1998 and did retail for $119, but you can get it at amazon.com for less than $60, usually under that. At ebay is the best place to get it, it is as low as $20 and no more than $40. It is completely passive and requires no electrical power supply to run it.
What is does is create psycho acoustic response by amplifying mixed signals that are lossed in the recording process and amplifying it in the mix. You will hear loss signals that's not normally processed thru conventional amplifier/speaker set up even with an equalizer which only alters the frequency. Sound processors are the way to go if you want to bring out all the instruments and recording in your music. Like anything, else you have to make adjustments to your your tone controls and equalizers if you have one connected to the loop. I do not recommend any reverbs that was so poplular in the 80's, as they are only generally used for preproduction and not post production or playback music.
The other tweak that will compliment any sound processors from enhancers to expanders or better known as range controllers or compressors such dbx 3bx series 3 or DS, for digital, or behringer, alesis brands, is called
a DAKIOM FEEDBACK STABILIZER at
www.dakiom.com this is an amazing product that is like a water filter in the audio world. it cleans up current going thru your system. It makes an instrument sound livelier. When this product is coupled with any of the enhancers mentioned, it creates the 3 dimensional pscyho acoustic effect that you are looking for in a live sound!
I have been experimenting with many processors since 1979. I have helped many others on this issue and they thanked me later even the high end millionaire i came across who simply just wanted to make his very expensive system sound a certain way that none of the high end sales folks could answer but trick him into just buying more unwanted expensive gear and cables. I told him about the inexpensive dakiom and acoustic research combo, he later emailed me and thanks me endlessly. I could have wished he would have just hired me on his company he owned....kidding...wishful thinking.
If you want to spend more on sound processors, here's a list of companies that make awesome sound enhancers:
BBE SONIC MAXIMIZER 362 SW, this can be used for stereo, dj applications, home theater etc...and professinal use
PEAVEY kosmos, they have an awesome subwoofer subharmonic enhancer.
APHEX AUREL EXCITER, this one is primarily a dj/professional processor used to multiply your subwoofer as if you have several installed, cleans up the low frequencies, you can however use it for home but using 1/4 inch plug to RCA adapters you can get at any dj store or radio shack.
SRSLABS have what they call circle sound found in kenwood and marantz receivers. I am not sure whether you can get one of their separate
sound processor called srs pro 220 spatial enhancer which was made in the late 90's...you might find it in ebay... or you can get one of their W.O.W ipod or pc cards used for enhancements...they are plug ins... they can be purchased thru SRSLABS.....
www.srslabs.com great company!
If you want an example for free their technologoy....download MSN MEDIA PLAYER from microsoft....and the media player contains the SRS sound processor on control pad after the equalizer controls....it creates a big difference with the equalizer and srs w.o.w connected or turned on....
there are other companies like BSR and HUGHES that emulated these sound processing companies, but each company has their own patent.
BEHRINGER is another company that makes good sound processors...
high end audiophiles use their digital equalizers for their tube set up...
I HOPE THIS HELPS ALL OF YOU who are looking to enhance your listening experience without spending thousands on your gear!
