Did they come as a set or are recommended to work with each other?
Since the sub is a Rokit 10s and the mains are Rokit 6's, I would assume they were designed to work together, and the literature of course recommends the marriage. Although I don't see much interest in them in these forums, the Rokits seem like OK speakers...
A Curiousity Question:
I mentioned the Mogami XLR-RCA adapter previously and both
j_garcia and
MidnightSensei agreed that I should just go straight RCA, as I shall (and I appreciate the recommendation very much!). Just a few minutes ago, I read on the Mogami site that this Mogami adapter is unbalanced. Out of curiousity, if I were to plug this adapter into my sub, using the XLR input which the sub expects to be balanced, would it work? I am guessing not, because if I understand correctly, balanced cables send a signal differential, while unbalanced cables send the straight signal, and I would think they were incompatible.
