How to connect an old Infinity SSW-10 to newer reciever?
cbl600r
I just bought an Infinity SSW-10 subwoofer for 40 bucks. My receiver has one "low level sub output".. The Infinity has a right and left input. Do I need to spit one cable into two? Or can i just plug a cable form the low level output to the left input on the sub and have have it work properly?
no. 5
no. 5
That should work fine.
By the way, are you referring to low level inputs or speaker level on the sub?
cbl600r
Thanks for the help! If i understand what you are asking. I am talking about the the low level. I am not going to hook up the part of the sub that accepts speaker wire..
cbl600r
Here's the manual for the sub. For future info if you don't already have it.
The manual is not very helpful as it was printed before dedicated sub channels.
Like no. 5 said you should be fine plugging it into the left input.
Yes. i did look that up. And it did not really answer my question. Well it probably did, but it just didn compute with me.
Anyway, Thanks for the link!!
