Mmmmm, ok. When I ran the EzSet/EQ mode, the three little beeps coming from the speakers sounded crystal clear.
But when I use the optical input, the sound is horrible, it sounds as if the music is in the house next door, there is no clarity.
When I used the speakers on an old 6 ohm system, the sounded fine.
I don't know, but I saw in a web page (unfortunately I can't find it anymore) that since my speakers are 6 ohm each, then they are getting 3 ohms from the amplifier.
And if the speakers are at their minimum, 4 ohms, then they would be getting 2 ohms from the amplifier.
I don't know if HK meant 4 ohm minimum when there are 4 speakers in the system, each speaker being a minimum of 8 hms.
Very confusing for me.
If speakers and amplifier specify 4 ohms as minimum, then it should work fine.
