Just curious - why don't you like having them on all of the time? Do the fans run while they are idle? I thought that those would dissipate pretty low power in the idle state, but I don't actually know.
I have amps and powered subs that use line level sensors, and I don't ever use those because the amps will switch off if the signal goes too low, then it takes some amount of time for them to switch back on again once the signal increases. So, if you are listening to music or watching a movie with quiet passages, you might find that such a solution will shut down the amps, and then you'll miss the first portion of the audio when the volume increases in the music/movie. It's just a note about those types of sensors. It would be nice if you could find one with a timer setting to indicate how long to stay powered up after the signal drops.
