5.1 DTS guy said:
... or should I directly connect the speakers to my receiver and output my subwoofer through the LFE output on my receiver. I can't understand what difference it would make. Thanks for any help.
Yes, this is the way. But, you also need to designate using a LFE speaker in your receiver setup menue. But, it is also helpful to read the manuals that came with the components.
There is a special .1 ch encoded with low frequency material.
And, only the signals intended for the channels in the bspeaker outs for them.
How else a sub may be connected comes in a later lesson
