I have a Sony Mutek Ddw2000 Home Theater, including the STR-DG520 Receiver.
Unfortunately, a receiver channel has been damaged, and has no repair.
I then need to replace this receiver.
These are the technical specifications of the damaged receiver, and of its speakers, which I intend to keep with me:
RECEIVER
Output power*
(6 ohms, 1 kHz, 10% THD)
Surround Mode Output (Reference) *
RMS Output
FRONT: 140 W per channel *
CENTER: 140 W per channel *
SURROUND: 140 W per channel *
SURROUND BACK: 140W per channel *
(*) Measured at 127 V AC, 60 Hz
Inputs:
Analog Sensitivity: 800 mV / 50 kohms
Digital: (Coaxial) Impedance: 75 ohms
Outputs (Analog):
AUDIO OUT Voltage: 800 mV / 10 kohms
SUB WOOFER Voltage: 2 V / 1 kohm
Tone:
Gain levels ± 6 dB in 1 dB steps
Playback frequency range: 28 - 20,000 Hz
SPEAKERS:
Front Speakers (SS-MSP16)
2 way system, 3 units, magnetically shielded
Speaker Unit:
Woofer: 160 mm, cone type × 2
Tweeter: 25mm, Horn Type
Cabinet Type Bass reflex
Nominal Impedance: 6 ohms
Dimensions (W x H x D) (Approx.): 250 × 950 × 274 mm
Weight (approx.) 14.1 kg
Center Speaker (SS-CNP16)
Speaker system: 2-way, 3-unit, magnetically shielded
Speaker Units:
Woofer: 100 mm, cone type × 2
Dimensions (W x H x D) (Approx.): 514 × 174 × 223 mm
Weight (approx.) 4.9 kg
Side Surround / Rear Surround Speakers (SS-SRP16)
Speaker System: Full Range
Speaker Unit: Woofer: 100 mm, Cone Type
Enclosure Type: Bass reflex
Dimensions (W x H x D) (Approx.): 171 × 216 × 163 mm
Weight (approx.) 1.5 kg
Subwoofers (SA-WP16)
Speaker System: Active, Magnetically Shielded Subwoofer
Speaker unit: 250 mm cone type
Enclosure Type: Acoustic Volume-loaded Bass Reflex
RMS output: 165 W (6 ohms, 100 Hz, 10% THD)
Input: LINE IN (input jacks)
Power: 127 V / 220 V AC, 60 Hz
Consumption: 80 W
Dimensions (W x H x D) (approx.): 335 × 410 × 412 mm including front panel
Weight (approx.) 10.6 kg
I would like the guidance of friends here on the forum, about what should be the RMS power per channel of the receiver I shall purchase, considering the rest of the home theater, i.e. the speakers, since the new receiver will work with them.
I appreciate the help.
