Hi all, long time reader first time poster...
I've set up my first ever stereo rig, and while I'm very pleased with it overall, I'm finding the treble a bit harsh at times, and I suspect much of it is due to the room. My question is do I need to try and get an EQ curve or other analysis of the room or should I just start treating?
For example, when listening to hi hat or ride hits on some equipment you get that really nice crisp "ting" attack. Really defined transient. I'm finding that a bit blury on my equipment. Also, distorted guitars are harsher than I am used to.
The room is far from ideal... its a living/room dining room long combo deal and I'm facing the speakers the short way. (maybe 10-12 feet?) The side walls are a large glass window at the front, and a sliding glass door to the back deck, but both are far away. The floor is hardwood and the seating is right against the back wall, which is bare. Wow, I feel like I just described the worst possible listening environment!
My speakers are 2 Paradigm Monitor 7 v6s (the latest) and a Yamaha RX-797. I am playing flacs so the source quality is good.
I've noticed some standing wave issues in the bass, in that I can hear a somewhat significant difference in different areas of the room, however I find the lows pleasing overall and this doesn't distract from my enjoyment so far.
First thing I'd like to try is just getting a large area rug as the floor is the hard surface closest to the speakers. Then I would consider treating the back wall with something (DIY OW 703?).
Should I be getting an SPL meter and test CD before I do any of this or should I just go for it?
Sorry for writing a book
Thanks
TMANIAC
