Hi Jamster. More people blow their speakers by underpowering them then over powering them. The closer you get to giving them the max wpc output the better they will sound & the more headroom you will have.
So if the max wpc of your speakers are 150wpc then give them anywhere from 125-150 wpc. You can probably pick up a good used amp. That way you get more bang for the buck.
Also know that you won't blow them up giving them more power. For example, my amp puts out 405wpc. My speakers max is 250. They play just fine, since my ears will give out long before my amp or speakers will!
