robjd
I am puting a home theater system in my family room and I don't know how powerful I need it. The room is 14x22 ft and has about a 16 ft ceiling.
I was thinking about the Harman Kardon AVR 435. Is that system powerful enough for the room?
Thank You,
Robert
djjimbftp
hello,
rob most stores give you a 30 return policy take one home and try it out. If you think it is loud enough keep it. If you buy speakers that have a higher sensitivity 90 or higher it should be fine in your room.
good luck,
markw
Thank You,
Robert
That really depends on the sensitivity of your speakers and how loud you like your music/movies.
robjd
I was going to use the Polk Audio R15's Which have a sensitivity of 89
markw
Well, that takes care of the first part of the questions.
