I am planning on building a dedicated HT room in my basement that will measure 12x17. I will have two rows and expect to sit about 12-13 feet from the screen. I plan to buy a 1080P projector. How large a screen can I reasonably go? I plan to watch normal DVD, Blue-ray and 85% HD TV on it.
drooze, are you hearing a certain theme here?
I believe the
ONLY way to know is to throw the image on the blank wall and go from there. After all, this is really about personal preference (if you haven't noticed)...
FWIW, I believe I have a 42 deg angle for my front row, decidedly closer than THX's 36 deg. I originally had the front row at THX, and the back row at roughly SMPTE, but I moved both further up because I realized I loved greater immersion. So much so, I went with the biggest screen I could practically fit, and the remaining space for speakers was an afterthought. I am presently researching well designed horizontal center speakers that are short in height.
There has been
only two times that I've ever preferred the back row. Once was for watching The Frighteners as the PQ is not up to par as with most of my purchases. The other was for a foreign film with subtitles. I have zero issues with the aforementioned "tennis match phenomena", but I find vertical movement of the eyes more difficult to deal with.
So if you will watch a lot of normal DVDs, I might say smaller screen as the inferior PQ may be hard to swallow. I have
only Bluray and HD-DVD hooked up to mine, and even then, Im only purchasing those discs that have top-notch picture quality, even relative to other hi-def movies.
Also, depending where you mount your PJ, you may be limited to screen size due to zoom capabilities of any PJ.
Lastly, I know we are only talking about size, but there are many things to know before you decide on the
technology of the screen you will use.
Just throw up the pic at a blank wall first.
