How in the world do I hook this up?
BARRACUDA1968
I got some advice on here to get a FEEDBACK DESTROYER PRO DSP1124P by Behrenger to EQ my subs so I bought one. I downloaded the manual and it has DIN plugs on the back. No RCA's?? It gets worse, I have 2 subs so I bought 2 of them. They aren't that expensive so I gambled. I hope I can buy cables that go from their DIN to RCA's. Can anyone tell me if I goofed or is there a simple solution.
I belive you'll want a few of these. DIN? I know there are XLR and 1/4" connections on that guy.
BARRACUDA1968
I will see if that type of connection will work? The DIN connection looks similiar to a S Video type of connection. I remember them from years ago on Kenwood car audio amps etc.
E
Eric Apple
On my dsp1124p, I use the TSR (1/4 stereo headphone plug) with a mono 1/4 adapter to RCA. I don't have DIN plugs on my 1124p, are you sure that's what you got ?
Also, you can EQ two subs with one dsp1124, it has two channels built in. Use the left channel for one sub, and the right channel for the other.
You can buy the 1/4 to RCA adapter at radio shack and many other electronic retailers.
Post up a link to a photo of the unit back or manual and we'll try to help you get this conneted.
jaxvon
jaxvon
The DIN connectors are for midi control. Don't worry about them. You're going to be working with the XLR or 1/4" connections on the other portion of the back panel. Just pick up some RCA to 1/4" adapters.
BARRACUDA1968
Thanks guy's, you are right. I don't have them yet so I downloaded the manual and the drawing wasn't very clear so I didn't see the other plugs. I will defintely need some help getting them dialed in. I'll be back with questions when I get them. You guys are great help!
