The voicing of speakers is largely a sum total of many design factors. A 1/2" difference in woofer cone diameter may not really matter a great deal as such other factors as the crossover points as well as its coupling with the box dimensions/matererial/shape and port size/location synergize with one another to deliver the frequency response the totality of the design was meant to deliver.
In general, however, taking into account some accepted principles in the physics of sound, the smaller the cone, the more inefficient it is to deliver lower frequencies. Conversely, the larger the cone, the more inefficient it is to deliver higher frequencies. There are, however, compensating design factors that can overcome such inefficiencies, like making a smaller woofer more excursive, or making a larger tweeter more rigid. There are 8" or 10" sub woofers that can sound as deep or even deeper than some 12" woofers, though the physics of sound requires that a larger cone diameter is needed to move a larger rmass of air the lower the frequency is. If I recall right, some dispersion trait will also change with frequencies as their wavelengths exceed driver diameter, but these can be overcome with the proper crossover points. In short, driver size can determine to some extent what the driver can deliver, but may not be a determining factor when choosing a speaker with other factors that went into its overall design. I couldn't make a recommendation either way, unless I hear them, as speakers are meant to when choosing. Just my thoughts.
