How important is speaker sensitivity?
twochordcool
There are very highly reviewed speakers that I want to consider but they have a lower sensitivity rating than other speakers that I am considering also.
89 db seems to be average.
But is a drop down to 86 db speakers very bad?
For example -
Now Hear This! SB-2 –
51Hz to 22kHz
86db
150 Watts
Now Hear This! SB-3 –
39Hz- 22kHz
175 Watts
86db???
Paradigm Atom –
70Hz to 20Khz
86 db
80 Watts
Paradigm Titan –
60Hz to 20kHz
86 db
100 Watts
Epos ELS-3 -
65Hz-20KHz
87db
100 Watts
4 ohms nominal
Ascend Acoustics CBM-170 -
69Hz to 20kHz
89db
200 Watts
Axiom M3ti –
60 to 22kHz
88 db
175 Watts
Axiom M22ti –
60Hz to 22kHz
89db
200 Watts
Energy C-3 –
46Hz to 23kHz
89db
125 Watts
Monitor Audio Bronze B2 –
42Hz to 22kHz
90db
100 Watts
6 Ohms
Unfortunately also, some of the speakers with the higher sensitivity don't seem to have as broad of a frequency response (Ascend CBM-170)
Please discuss!
MacManNM
MacManNM
IMO there is nothing wrong with the lower sensitivity speakers, as a matter of fact I feel that they are more accurate in general.
MDS
By that logic, 83 dB speakers would be even more 'accurate'. :confused:
The only difference is that 86 dB speakers will require more power to achieve the same output SPL as a higher sensitivity speaker. If they have good frequency response, you like the way they sound, and they are in your price range, then by all means get them.
Spiffyfast
Spiffyfast
Just put an amp to them if your worried about not getting enough sound, should be fine either way though
MacManNM
MacManNM
It is simply an opinion, based on past experience. I believe I am entitled to one!
Ah, a feeling. It would be better to know, wouldn't it?
Everyone is entitled to one, even me. But some are worth more than others or else nobody's would be worth anything, right?
Buckeyefan 1
Buckeyefan 1
It all depends on what you use to drive them. My Denon 3805 is just enough to drive my Polk 7.1 that are rated at 89dB (at least the RTi10 towers). If you don't have at least a receiver equivalent to a 3805, I'd suggest looking at speakers at 91dB or higher. SPL ratings don't tell the quality of the speaker, but do state how well your amp/receiver will drive them. I'm sorry I bought speakers with an 89dB rating. In hindsight, I would have preferred a similar quality speaker rated in the low to mid 90's. Now I plan on buying a separate amp to power the woofers in my towers. In my case, I have a very large room which opens up to an eating area/kitchen. If you are in a smaller room, it may not be necessary. SPL ratings, IMO, are extremely important if you don't have the cash to purchase a hefty receiver or separate amp.
A 3dB spl sensitivity drop means that you need twice the power from an amp to play at the same loudness. Every 3 dB difference is a factor of two. If you want it 3dB louder, you need twice the power. 3dB spl is not that much of a change, especially at either end of the audio spectrums where the ear is less sensitive to level changes ;)
MacManNM
MacManNM
So you are going to follow me around and take shots at my posts now? That's real mature.
annunaki
annunaki
Moderator
Guys let's not use the public forums for personal attacks. If you wish to "duke it out" please use PMs.
miklorsmith
Good question!
I personally love high-efficiency speakers, even with their quirks. They do some things that I haven't heard out of lower-efficiency offerings. For purposes of my comments, all your listed options would qualify as low efficiency. I would say high efficiency starts around 92 or 93 db. My main speakers have a 101 db rating and they crank ridiculously with 6 watts.
That said, it isn't everything. I just bought (en route) a pair of VMPS monitors for my living room arrangement that rate at 90 db.
Within the range you cite, I wouldn't worry too much about it.
Also, I'm probably regarded as something of an eccentric around here, so take with a shaker of salt.
N
nm2285
You ask, "how important is sensitivity?" I ask, what "amp do you have?" With most decent amps, you shouldn't have a problem with any of the speakers you listed. I used a Denon AVR-1604 (75 watt) and a JVC 100watt combo receiver/dvd player to drive NHT SB2s for a while (not together of course). Then I moved to a NAD C370 (120watts of REAL power). The NAD was obviously better, but really only at higher volumes. It was better able to control the drivers. Sound quality was not terribly different at lower volumes.
You should really worry about sensitivity if combined with low impedence.
Privateer
You do not understand I think that mtrycrafts is physicaly deaf yet he argues on an audio forum about how things sound.
mulester7
mulester7
.....Privateer, please do us the decency to at least be vague, haha.....
abqhudson
Dynamics.
To my ears, speakers with higher efficiency seem to have better dynamics and speakers with lower efficiency always seem a bit more laid back to me. Higher efficiency speakers just seem to be able to keep up with transients better. No flames - just my opinion.
Jim
O
Ohmage
Jim
You may not be far off with your thoughts. Bass notes require a surge of power from your amp to sound adequately; if your speakers have a low sensitivity, then you better have a powerful amp with alot of reserves when those bass notes hit. So obviously, low sensitivity speakers require a more powerful amp to sound dynamic and distortion free. It is all about control of those bass frequencies.
Ohmage.
Racercarp
High sensitivity
Hi,
Just a thought but whatever sensitivity speakers you choose to use should be mated with the receiver or amp you are looking at using them with. The sensitivity rating is how many watts it takes to drive a certain speaker (typically 1W at 1mv) to a certain level (or spl) so an 86bd speaker will take more power to drive efficiently than say an 89db speaker (and less so for a 92db speaker).
It's a strange formula but it takes expotentially more power to drive just a small difference in db rating speakers. So for instance it may take 50W to drive 89db speakers to 100db (sound pressure level) when it will take roughly 100W to drive 86db speakers to the same sound pressure level...
Take this into consideration if you have just a receiver or integrated amp!
Racercarp-
Audiophile from Seattle...
