Thought I'd pass this solution along.
Have a new sub and had the grounding hum. Sub was connected to receiver from the receiver's subwoofer output (LFE) by a sheilded RCA cable. Receiver cross-over set to 80 and the sub's cross over disabled. (as per instrutions that came with the sub and from what I have read online)
Had the hum, which I temporarily resolved by using a cheater plug on the 3 prong sub's plug. (From what I understand, this confirms the hum is from a grounding loop. Removed the cheater plug since not a safe solution)
Here is how I solved the hum. I turned the cross-over circuits in the sub back on. Set it to the highest setting (160) and hum is gone!!
I figure since the receiver is set to a cross-over of 80, having the sub set to 160 should make no difference. Right?
Anyone know why this would resolve a grounding hum?
ps never knew what I was missing without a sub. All I can say is..... Wow
