skasol
I am thinking of getting a receiver that allows me to listen to internet radio, I am thinking between the new Yamaha RX-V2700 or the denon 4306, the question is, how hard is it to set up, and will I be able to listen to www.1035.com radio station, that is the only reason why I am buying it, my girlfriend loves listening to the coast, and I will like her to be able to listen to this while I am at work. please advice, thank you. I currently have the denon 2807, but I am able to upgrade to either one of those.
jcPanny
jcPanny
Sb3
How about buying a squeeze box 3. For <$300, it will give you access to internet radio and wireless audio streaming from your PC.
skasol
thank you, I am not sure what that is, I will do a search and look around. thank you for your help.
G
googdot
i second the squeezebox 3 - i love mine! fully customizable in every way you can think of, and you can listen to any internet radio you'd like on it. reviews all over the web, but good summary and info at http://www.slimdevices.com
skasol
thank you for your reply, but it seems as though it will add more clutter to my already cluttered Audio rack, as well as almost being the same price for the receiver with the built in internet radio, the question was how hard is it to set up if it's already built in? thank you.
ardo
How hard is it
SO FAR, FAR FAR FROM EASY
Hi, I bought mine this morning, and its not an easy task to read the manual
compared to my old Yamaha rsx 2300. You have to be and stay calm and have plenty of time to spare, but when you hear it sing for the first time in your living room, you know, you have made the right choice. It is not perfectly setup, but even like it is it is a joy to listen to.
