Scott,
> Corner placement rocks if you need to pump up the bass, and it minimizes first reflection problems. <
Yes, however one big problem with corner orientation in a rectangular room is you then have a corner behind you too. And that corner focuses all the sound right back at you, offsetting at least some of the gain from having angled walls.
--Ethan
