How does PolkAudio RTA 8t compare to Bose?
V
victor
How does PolkAudio RTA 8t compare to the following
Bose - AM6IIIBK
Sony - DAVHDX500
Definitive Technology - PROCIN600BK
for home theater and for classic music listening purpose?
Thanks.
- Victor
F
flippo
Of the choices given I would take the Def Tech. Bose is way overpriced and are not very good - they just have very good marketing. Sony doesn't make very good speakers either as far as I know. The Polks and Deftechs are better.
3db
3db
Bose - AM6IIIBK
Sony - DAVHDX500
Thanks.
- Victor
Polks and Def Tech over the other 2 brands you mentioned anyday, everyday.
BOSE is over marketed over hyped expensive crap. I'd even choose the Sony over them.
Joe Schmoe
Any speakers that are not Bose are better than Bose by definition.:)
rnatalli
From the OP's choices, I'd take DefTech over Sony and Bose any day. Do get out and listen though as there are lots of good speakers out there.
cfrizz
If you check my signature you will see a pair of 17 yr old Polk RTA-8T speakers listed driven by listed equipment & have never sounded better.
They will stomp all over Bose 24/7/365.
So by all means pick them up & enjoy!:D
