Wow, this is all very interesting stuff. Thanks everyone!
MDS said:
...you have to FTP your files to the server and configure the site yourself.
Is the reason it must be FTP'd so that
you yourself are directly (albeit remotely) building the website? In other words, the web hoster maybe providing a domain and allowing you to link it to an I.P. address with space but "
that's all the service yer gettin' fer yer money mate!"? Does that about sum it up?
MDS said:
Google for 'web hosting' and you will be overwhelmed with the number of companies that provide the service.
Indeed, I am. I clicked on one of the first and for around £14/$8 a year you get 150MB of free space and a free domain name. £14's peanuts!
sploo said:
Step 1 gives you some space (a directory) on a computer, which has an IP address (e.g. 66.249.93.104). At the time of writing, you'll find that'll take you to google.
Ha! I didn't know you could paste an I.P addresses into the address bar at the top of Internet Explorer and jump straight to a site! (I usually type "www.blah blah")
So what's to stop someone FTPing junk into a randomly selected I.P. address which, if the FTP works, would presumably fill someone's site with said junk?
sploo said:
Step 2 links the domain name you specify to the IP address on your box
Right, so a domain is just the glossy name that covers the I.P.address? As an example, I'm assuming that the Audioholics website is basically just a number (like 66.249.93.104), but its domain is
www.Audioholics.com and when you type that into the address bar in Internet Explorer some kind of search must take place ("finding site" on the bottom bar) until the link to the I.P. address is found and voilla! You're there!
Correct? If so, then presumably pasting in the I.P. address of the site (if known) jumps straight to it without having to search for it via a domain name, i.e. this method is the most direct. Correct?
sploo said:
You can hand code HTML, but a package like Dreamweaver makes webpage creation easy. IMHO MS Word is not really a good package for this job.
Hmm, now
that's a bit pricey. Maybe I'll just stick with Word for the moment.
AKAJohnDoe said:
I registered a domain, redirected it to my ISP web space. Built some rudimentary initial pages in Word, saved to HTML format, FTPed them up. All done between morning espresso and lunch.
Yep, I took a look at that. Seems perfect as a beginning for me. Thank you very much for taking the (short
) time; I really appreciate it.
So, still no recommendations for any books? Don't you have any, or are they simply not worth bothering about?
