How does audyssey work with 2 subs?
I
Inertia
Just wondering... if you only have one subwoofer output and you have to use a y splitter for the second sub how does audyssey work especially if the subs are in different spots of the room?
G
guitarplyrstevo
I don't think it will work like that. I think it will play the signal to both subs at the same time and calibrate it from there.
I know a lot of Yamaha amps have dual subwoofer outs so they might be able to calibrate two separate subs, however I could be wrong.
I
Inertia
so anyone know how you calibrate 2 subs with audyssey?
MidnightSensi
MidnightSensi
Huh? It's just a microphone connected to an automatic parametric EQ. It will work. It doesn't know the difference. Just try to get the response fairly linear before running the audyssey. It can't cut and boost individually, but it will operate.
G
gus6464
By doing it this way it will negate the benefit of having multiple subs in the first place as each sub has to deal with different room modes if they are in separate locations. This would not be a problem if the subs were stacked or right next to each other but if they are in different places in the room it's a whole different story.
dagoods
Hope you don't mind me jumping in here.
You could also try this with your SPL (if you have one). I have a Yamaha RX663 so I am not familar with Audessy. But I have 3 subs and this has worked for me using an SPL meter and the tones from the receiver.
Run Audessy with only one sub on. Adjust the level of the sub at the sub. Turn it off. Turn the other sub on and run through the process again. Keep in mind that if each sub is at say 71db that combined you will get a higher reading (around 3 to 5 db more).
It's a easy way to get them balanced between each other. Don't forget to set your reference level for the test tones. I set mine at 75db.
I am currently going through the process of installing a BFD1124P. It is a challange to say the least. I have heard it on a couple of friends setups and it is amazing. I hope to have mine up and running tomorrow night. I have been working at it the last 2 nights.
The BFD 1124P, midi cable, and 1/4 to RCA cables cost me about $180.00.
I am by no means an expert on this stuff, but I sure enjoy it! This is something that has worked for me. I am sure you will get many opinions and views.
Good luck and let me know if I can answer any questions.
