how do you solder thread?
E
elmer d
Several times I have found a thread like stuff used in the place of real wire. Anyone know what this is and how to solder the imposter. Normal soldering dont do it.
Adam
Adam
Welcome to the forum!
Like Jamie, I don't really know what you are talking about. Perhaps you are referring to dielectric or insulation.
Are you referring to Monster Cable? Perhaps their speaker wire? Monster sometimes has a dielectric core that runs down the center of the copper strands.
E
elmer d
???????, exactly. I cut open cable to do a project and this stuff is in the place of real copper wire. Touch your meter to each end and you get nothing though if you are successful at getting a dab of solder to stick then the meter will read. Even the stuff that looks like copper does the same. It just wont take to normal soldering methods.
Alex2507
Alex2507
Ignore the thread.
It's there but it doesn't do anything so you don't have to do anything with it.
Why would you want to solder the thread?
Phil Taylor
Phil Taylor
I've seen mic cable like that before with a really fine copper wire intertwined with a fabric thread - it's a large PITA. Try using some flux or rosin core solder to help tin it first before soldering to the connector.
E
elmer d
Ignore the thread ? it doesn't do anything?
Dude. It is there because it makes the connection. Maybe its me but there is solder on each end . It is the wire but it is not wire. ??? Spread the thread/fiber/stuff apart and there is no wire. yea, I know its weird. This particular part is in an adapter connection from Hong Kong. I’ve seen the same in mic wire from a Motorola product. I need to cut and reconnect it. But how? Something solders it. It something can I can. I just have to find the how.
Thanks Phill. While I have got one or two to tin most will not take. Solder just rolls off. most annoying
jamie2112
I am having a hard time seeing this cable in my head. Could you please post a pic of the wire in question?
Alex2507
Alex2507
Sorry for the diversion, I was thinking of a different kind of thread that is not wire but thread.
Phil Taylor
Phil Taylor
I know - like it's teflon or something similar - a real PITA. Persistence is a virtue - you may try dipping it in flux, then hold your iron on the end of the "wire" and see if it will wick solder into it. A really hot iron may help.
camshaft
Hmm, it's very hard to visualize what you're talking about. Some wires have a coating on them though, and by putting a dab of solder on the end you melt away the coating and make contact with the core. I don't know whether thats what you're talking about though. If it's teflon it won't melt as easily though.
Austin
E
elmer d
Thanks guys. I have an iron with a selectable heat range. I will turn her up and see what I can burn up. Jamie2112; picture I will be glad to do but I do not have a http location for my pics.
Adam
Adam
For photos:
  • You can get a free account at Photobucket or Flickr.
  • You can also attach images to your posts if they are under 100k (I think that's the limit).
Ray Kimber
A semi possibility
Semi conductive, that is.
This thread (pun intneded) has me scratching my head, but I do have some possibilities.
The first is that you have some unusual form of Litz conductor. Most of these can be rendered solderable by dipping them in a solder pot - an iron might do it, but usually not. There are a few Litz-like conductors out there that do not respond (very well, if at all) to a solder pot and those need to have the microscopic thin layer of insulation removed by abrasion, such as one of these machines:
http://www.eraser.com/catalog.cgi?mode=details&product_id=1391
However, by your description you might well have a metallized filament (like an inside-out Litz) or some sort of semi-conductive filament. Neither of these would be solderable by heat AFAIK, but would instead have to be terminated by crimping or using a conductive adhesive. In any of these cases the termination process is likely very precise and very specific to the "wire".
Kind regards,
Ray
BMXTRIX
BMXTRIX
I think I know what he is talking about.
The Nintendo Wii remote sensor has a fairly thin wire going to it, and I have spliced into it... When I cut the wire and stripped back the housing the actual conductors were nothing but extremely thin copper wire strands interlaced with actual threads.
I ended up using a match... very carefully... to burn the threads away. A couple of times I caught the copper threads on fire as well and had to start over.
It ended up working out okay, and I did not solder, but used a Dolphin connector to extend the Wii LED emitters.
jamie2112
Good to know I didn't have a freakin clue...
Alex2507
Alex2507
You need to hone your guessing abilities. You know what I mean?
How did the OP get red rep with 4 posts?
Why are we mot being told what this wire is for?
jamie2112
Duh................Hello Alex my name is Jamie I think you know me maybe:rolleyes::D
