How do you calculate power draw?
RoadKill666
My living room only has one outlet and with the amount of stuff I plan on adding to the living room, how do I know if my outlet can handle it or if I need to get another one installed and ran to the breaker on a separate line?
The plan is for that one (2 sockets) outlet to handle
1 large screen tv
3 gaming consoles
1 receiver
1 amplifier
two 300 watt towers
two 500 watt subwoofers
an 11 plug power conditioner
mini NUC pc
3 controller docs to charge 6 controllers
2 docs to charge 2 headsets
My plan was to have everything going into the power conditioner and then that going into the wall but I think it's too much power for one outlet. I know it's not cheap to get an electrician to come in and drop more power but with how much I'm gonna spend on everything it should be worth it right?
Verdinut
Verdinut
1 large screen tv
3 gaming consoles
1 receiver
1 amplifier
two 300 watt towers
mini NUC pc
If your TV set is a plasma one and you only have a 15 amp circuit, there's a very strong possibility that the breaker will often trip with the equipment connected to it. That type of set draws a lot of current, a minimum close to 4 amperes.
If not, then everything would depend on the type of amps driving your towers and subs (Class AB or D), your listening distance from your speakers and how loud you like to listen to music and movie soundtracks. Why don't you try using the equipment, and preferably measure the line voltage while operating it. It's possible that you will be able to operate the whole system, but should the voltage appreciably drop with loud SPL, then you will need to have an additional circuit installed.
Why do you have a power "conditioner"? The speakers don't use power quite the way you think when it comes to their max ratings and your subwoofers likely have their own separate draw/amps in any case. I run for stuff off an outlet than you in any case without issue. I'm not trying to set spl records either...
1 large screen tv
3 gaming consoles
1 receiver
1 amplifier
two 300 watt towers
mini NUC pc
Look at the sticker near the power cords on the equipment that uses power- the speakers and anything with a wall wart power supply are immaterial. That means, add the power shown for:
TV
Gaming consoles
Receiver
Amplifier
Subwoofers
Mini PC
You aren't likely to use all three gaming consoles at the same time, so pick the one with the highest consumption. Once you get the total Wattage consumed, subtract it from 1500 (a safe estimate for the de-rated 1800|W equivalent maximum for a 15A circuit.
If it doesn't exceed 1500W, you should be fine and need to realize that it's not an average spec, it's the maximum, so you aren't going to open the breaker under normal operation.
V
viorelc
Actual power draw is measured, and it might be the most realistic way to assess your needs. Max power is estimated, by adding the max powers of the devices you tend to have on at any given time. The speakers’ power ratings matter only if it is about the consumption from the power outlet (110/220V ac), not about the audio signal from the amplifiers. Specs of the actual devices might mention both.
I use one outlet for all my main audio-video space. That’s an 85” OLED Sony TV, Denon AVR-2200W, 2 powered 12” subs and a Technics turntable, all of them being on at various times, and using reference level when watching some movies. I also have some other gadgets in the same outlet, but their power consumption is of little significance. This is just an example, your equipment and their use may vary.
RoadKill666
I've had one for my living room for a long time so when I decided to make the jump to a much much bigger and more powerful living room set up, I was going to get rid of my 7 sockets and get an 11 socket conditioner just for safety and peace of mind. I understand I could just get a surge protector but felt this was a better option for such expensive items.
How does a conditioner help at all? You live in a third world country with some seriously bad ac lines or something? Might want to review some of these
1 large screen tv
3 gaming consoles
1 receiver
1 amplifier
two 300 watt towers
mini NUC pc
One easy way is to get the Kill-A-Watt meter and actually measure the total as you keep adding more to that outlet.
How can you have only 1 outlet? Very Old house? What size is the breaker for that outlet?
One outlet can still provide quite a bit of juice...I'm stuck with one for a fairly large system. Depends on total draw at a given time, which would likely be within the limits of a single outlet at a given time unless trying to set spl records or something....
Eppie
Eppie
What highfigh said above. ↑
Those are maximums and regular use will be below that. If you are using a power conditioner as opposed to a simple surge protector, add that into the mix as well. I have a plasma TV (uses considerably more than LCD), AVR, 3 game consoles, cable box, phono, DVD player, VCR and subwoofer all on one circuit without issues. Not all components are on at the same time so typical use is a lot less than the estimated maximum. Worste case scenario run the system loud for a while and see if the outlet or the plug on the power conditioning gets hot. If they heat up without tripping the breaker then you are close to the rated 15 amps and should consider adding a circuit, but I doubt that will be the case.
